Camera was working and stop.I don't do anything. It's just stop work. When I try to start camera it's write "unhappily the camera stop working". That's it. Camera as device is working. Thru Instagram I can make pictures. That's the problem?
try this
Settings > apps > all > camera > clear everything > restart your tablet > try again
I was trying and it's still not work
In that case you might want to try reinstalling the tablet software. Use Update Service to reinstall it and check if you can get the camera application working again.
Sorry but this software is for Windows.I have Android in Ukraine
Please try following Johan’s advice. We are aware your phone is running Android however the software in question needs to be installed on your PC which will then connect to your phone to repair the software.
Don't forget to mark posts that answers the topic as Accepted Solution.
If you find any post helpful, press Kudos.
What are your thoughts about this forum? Let us know by doing this short survey.
OK, I reboot my system. And it's dosen't working at all.
Do you have some another ideas?
Thank you.
When you say "reboot system" do you mean that you have run the software repair as above?
Yes, I instal program, which you sugest. After I connect my computer to tablet and reinstal the Operational system.
