when i upgrating lollipop 5 my device, notebook shut down, and my devices can not power on.and its not connect via pc companion. How i connect switched off device to notebook and upgrate again? Help.
You need to repair,in that case the device needs to be turned off.
You may need to perform a software repair using PC Companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 80% battery.
Make sure the device is not connected to computer or laptop and turned off (sometimes you have to press power button and volume up until the device vibrates 3 times or on some devices you have to press the small button near the SIM tray or on the back of the device).
Open PC companion->support zone->phone/tablet software update->repair my phone/tablet blue highlighted.Follow the steps given,do not connect your phone until prompted to press volume down while plugging USB cable. If PC companion does not start the repair process, you might need to run it in compatibility mode with Windows 7 (in some cases XP).
my phone shut down and cant power on. Pc companion cannot connect my devices.
Charge it for 2-3 hours, turn it off and start the repair procedure. Please follow the steps exactly.
I TRY volume down, and connect usb . when i want upgrate device, companion said me. power your device. Can pc compaion upgrate device althoug device although device is switched off?
