That's entirely on your carrier, perhaps they have some down towers or they just have bad coverage in your area.
Boot in >>> safe mode and check again, as for the LTE bands, settings > about phone > status > signal status
what do you see?
If the phone heats up, the screen will dim
Signal Strength
| -67 dBm | Minimum signal strength for applications that require very reliable, timely packet delivery. |
| -70 dBm | Minimum signal strength for reliable packet delivery. |
| -80 dBm | Minimum signal strength for basic connectivity. Packet delivery may be unreliable. |
As you can see, the problem is network coverage, which will drain your battery faster and it will heat it up faster.
Hi
I have an issue with my new Z3+ ,when i connect to any pc with a USB cable, i only hear the sound for plug in, but nothing else happens:
- i dont get the automatic notification to choose charging or file transfer on my sony
- The mobile dosnt charge
-& Phone is not discoverable on the pc
also microphone voice is not good so my phones heraing of other caller cant listen my volume
I have the exact same problem with usb today but it was working ok a month ago still on Android marshmallow
Did you manage to solve it?
If the signal is weak a temporary fix is to switch to 3G and see how that helps the battery.
